lacamastraveler
Apr 12, 2024Aspirant
Modem Dropout
My CM 1000 lately has lost communication. Sometimes it quickly comes back on, other times I have to reboot and twice I've had to call TDS and have them send me a boost. It went off around 10 a...
- Apr 13, 2024
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. Thats on them.
lacamastraveler
The Cable Connection Status is Good
My Router is Synology RT2600ac with a mesh Synology MR2200ac in another location.
The cable is labeled Cat 5e
Are you saying you think the problem is not the modem, but the communication with the router?
Thank you.
Apr 12, 2024Guru - Experienced User
WE need to see that data from the cable connections page. There is a long page there of data that you can copy and paste here in the forums so we can see the values there. Help to determine more if this is a signal issue rather then a modem issue. Many factors on the ISP signal can be a cause of modems not working right. The events log points to that already.
