lacamastraveler
Apr 12, 2024Aspirant
Modem Dropout
My CM 1000 lately has lost communication. Sometimes it quickly comes back on, other times I have to reboot and twice I've had to call TDS and have them send me a boost. It went off around 10 a...
- Apr 13, 2024
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. Thats on them.
lacamastraveler
When you say "items mentioned" which items are those?
Did the event log I attached to my original post help. I've been down briefly and then back up since I began the last two posts.
I really appreciate your help. The only way I will be able to communicate with TDS is to give them specifics, otherwise they will blame on my hardware. They are most difficult to deal with.
Thanks, Jim
Apr 13, 2024Guru - Experienced User
- lacamastravelerApr 14, 2024AspirantThank you for your help.
