jmo562003
Jan 30, 2017Follower
Modem ethernet cable light flashing amber
On my CMD31T cable modem, the ethernet light is flashing amber and one of the two upstream lights is out. What does this mean?
DarrenM
Feb 01, 2017Sr. NETGEAR Moderator
The ethernet light just means its connecting at a different speed so that is nothing to be concerned about about the upstream light off means its only using one upstream which is not a big deal if you are still getting the correct upload speed from your ISP.
DarrenM
