hariri
Dec 17, 2020Aspirant
Modem froze
Today I walked in my home and realized there was no internet connection. Looked at my router and realized there are no lights in the front. But the lights in the back where you plug in the Ethernet co...
Dec 18, 2020Guru - Experienced User
When you reset, try and hold the reset button for up to 30 seconds. Make sure the coax is unplugged.
You can also try a 30/30/30 reset.
Push reset for 30 seconds while powered on
power off while still holding reset for 30 seconds
power back on while still holding reset for 30 seconds.
If that doesn't work, the device might be fubar'd
