lxstasy04
Sep 11, 2019Aspirant
Modem keeps dropping connection
I keep having problems with it randomly dropping and won’t come back up unless I reboot it. I have been fighting this for a while. ISP says nothing is wrong on there end. I’m at wits end with this so ...
Sep 11, 2019Guru - Experienced User
What ISP are you using?
the cm500 is a 16x4 modem. Not sure if this is true for all isp's firmware but in my experience if there isn't all the channels to lock for the modem, they still show but not as locked. Yours is only showing as a 8x3?
lxstasy04
I am using Shentel in northern va. I have a 150mbps down and 10 up. Not sure how many channels supposed to have. Is there anyway I can find out?
- plemansSep 11, 2019Guru - Experienced User
I don't see the CM500 as even a supported modem for your network. Here's their list of supported devices.
https://www.shentel.com/cable-east/support/guides/modem_list
- lxstasy04Sep 11, 2019AspirantYea I had a arris that was doing the same thing as this one. I picked this up just to test to see if it would do the same thing and it does. I call the isp and they set it up and said it was good to go.
If you've got 2 modems doing the same thing, it tends to point back to the ISP. I know you've been arguing with them about it. Not sure what else they expect you to do if you've replaced the modem and are still having issues. It kind of points back to their line
