lxstasy04
Sep 11, 2019Aspirant
Modem keeps dropping connection
I keep having problems with it randomly dropping and won’t come back up unless I reboot it. I have been fighting this for a while. ISP says nothing is wrong on there end. I’m at wits end with this so ...
Sep 11, 2019Guru - Experienced User
If you've got 2 modems doing the same thing, it tends to point back to the ISP. I know you've been arguing with them about it. Not sure what else they expect you to do if you've replaced the modem and are still having issues. It kind of points back to their line
lxstasy04
That’s what I been trying to tell them. Thanks for all the help I appreciate it
