Jammo
Oct 16, 2021Tutor
Modem reboot helps for 5 minutes then needs repeat
Greetings, I am experiencing up and download speeds that vary alot. I pay for 110mbps down / 10up. At times it gets so slow that I can't load web pages. When I do a speed test it shows betwee...
- Oct 20, 2021
Looks like he fixed it. Everything is working as it's supposed to.
Jammo
Oct 16, 2021Tutor
Sorry about this. I use and send screen shoots all the time, but I can't make it work today.
| Upstream Bonded Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
Oct 16, 2021Guru - Experienced User
got channels 1-10? channel 11 has errors and your power levels are pretty high
- JammoOct 16, 2021Tutor
Thanks plemans,
Any thoughts on resolving these issues? I will research further, but can you give me a ballpark for what power levels are acceptable and how I might change them?
1 Locked QAM256 17 591000000 Hz 6.6 dBmV 39.7 dB 0 0 2 Locked QAM256 18 597000000 Hz 3.7 dBmV 37.5 dB 0 0 3 Locked QAM256 19 603000000 Hz -2.7 dBmV 30.9 dB 2938948 496739 4 Locked QAM256 20 609000000 Hz 4 dBmV 34.7 dB 34146 1722 5 Locked QAM256 21 615000000 Hz 9.1 dBmV 40 dB 70452 3212 6 Locked QAM256 22 621000000 Hz 11 dBmV 42.4 dB 656259 20499 7 Locked QAM256 23 627000000 Hz 11.3 dBmV 42 dB 182292 18319 8 Locked QAM256 24 633000000 Hz 11.6 dBmV 42.1 dB 28482 61 9 Locked QAM256 25 639000000 Hz 11.6 dBmV 41.9 dB 29217 19405 10 Locked QAM256 26 645000000 Hz 11.1 dBmV 41.5 dB 46234 4963 - JammoOct 16, 2021Tutor
I had my ISP send a tech out. He replaced the modem with a DOCSIS 3.1 and about 8 feet of old 5.9 coaxial cable from where it comes in the house to the modem. The previous guy didn't do this...
Hopefully that's the end of it.
- plemansOct 16, 2021Guru - Experienced User
Hopefully!
- FURRYe38Oct 20, 2021Guru - Experienced User
Any progress on this?
- JammoOct 20, 2021Tutor
