afredwing
Jul 11, 2022Tutor
Modem resets to factory settings
About every 3 months my modem/router inadvertently resets to the factory settings, to include network names .... This occurs as I am watching TV or using a device. All my network settings, network names are all lost so no devices work. I have to delete the Nighthawk APP and reconfigure the modem router just like I got it out of the box. I have a Nighthawk CAX30. Any guidance would be appreciated.
1 Reply
It shouldn't happen.
What you could check is if the firmware is upgrading or the isp logs are sending a reset. I've seen that happen with firmware upgrades. Problem is, after the reset, the logs are wiped so you can't really even check that.
Have you tried doing your own factory reset? Maybe reinstall the firmware (in case something in firmware is corrupt) and then do your own factory reset/reinstall. Maybe a setting is corrupt but its not wiping out everything
