travelnyokel
Aug 07, 2023Follower
Modem Router Combo C6300 v2 only connect to guest network
I have the modem router combo C6300V2. This morning my main network disappeared. I can still log in to the guest network. I cannot login to the router or the app. I have restarted the router, compute...
Aug 07, 2023Guru - Experienced User
Power OFF the modem. Disconnect the ISP coax line. Power ON the modem. After it seems to start up, press the reset button in back for 10 seconds then release.
Check the front LEDs for wifi enabling and see if default SSID is present.
Set up the modem from scratch using a wired PC and web browser.
Re-connect the ISP cable coax line.
