Ross321
Nov 26, 2024Tutor
Modem/ Router Dropout
I'm getting intermittent "not connected to internet" message across multiple devices. I have a fire tv stick connected to wifi, it will stop streaming and then restart on it's own, or at worst I'll ...
Nov 26, 2024Guru - Experienced User
Which ISP is the modem connecting too?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Smart connect enabled?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
