Ross321
Nov 26, 2024Tutor
Modem/ Router Dropout
I'm getting intermittent "not connected to internet" message across multiple devices. I have a fire tv stick connected to wifi, it will stop streaming and then restart on it's own, or at worst I'll ...
Nov 26, 2024Guru - Experienced User
Is it saying "connected, no internet" on devices?
Do wired devices drop? or just wireless?
The goal is to determine if its a wireless issue or a modem side issue
A copy of the event logs and cable connections page will help check the modem side
- Ross321Dec 22, 2024Tutor
Thanks for the replies and suggestions! This router is in a condo I'd not been in for a couple years. When I returned, the connections defaulted to 5GHz. I changed it over to 2.4, and that fixed the drops. Fortunately, 2.4 works fine for my needs.
I don't know why 5GHz drops occur. The router is in the same room, within 30 feet or so of most devices with no intervening wall or obstruction. I'll bookmark this thread and return to try the fixes if I find I need more speed in the future.
