miffed
Apr 20, 2023Aspirant
Modem/ Router dropping all 5G connections every 12 hours. Netgear Model # C6000v2. Firmware V1.03.04
Hi - I was wondering if anyone has come across this before. The modem/router drops all wifi connections to all devices (5 total) exactly 12 hours after it has been restarted. When this happens the ne...
Apr 21, 2023Guru - Experienced User
I'd try a factory reset so you can access the GUI to get the cable connections page and event logs.
Those are a bit key with cable modem/routers.
Do wired devices drop?
- miffedApr 21, 2023Aspirant
Thanks. I did find one hit from someone that said the factory reset restored access to the Event Log. We will try that.
There are no wired devices to the router. All connections are wireless.
