Sotelokid
Apr 09, 2020Aspirant
Modem Router Dropping Speed. Netgear AC1750 Wifi Cable Modem Router C6300v2
Recenlty bought this modem and ive noticed my speeds will drop. When i do a reboot my speeds will come back up 200mbps+. Not sure what is going on but ive checked to make sure things are connected an...
Apr 10, 2020Guru - Experienced User
If you log into the modem's connection page, get a screen snip of all the connections info (upload/download/snr) and post it on here. even if its multiple snips. Also get a screen snip of your logs.
If you have any coax line splitters, attenuators, or amplifiers in line, remove them. If possible, directly connect the modem where the coax enters the home. this prevents wiring wthin the home from being the issue.
Sotelokid
Apr 11, 2020Aspirant
