Sotelokid
Jul 13, 2020Aspirant
Modem Router Dropping Speed. Netgear AC1750 Wifi Cable Modem Router C6300v2
Recenlty bought this modem and ive noticed my speeds will drop. When i do a reboot my speeds will come back up 200mbps+. Not sure what is going on but ive checked to make sure things are connected a...
Jul 14, 2020Guru - Experienced User
speeds drop over wireless, wired, both? Or 2.4ghz/5ghz? Details are important since we aren't there.
when it drops, do you still pull full speeds over wired?
Do you have a screen snip of the cable connections page and logs?
I'd also recommend if you have any splitters, amplifiers, or attenuators in line to remove them from the coax line.
- SotelokidJul 14, 2020Aspirant
They drop on both ....wired and on wifi. its odd and yes let me get a snip and i will post again. Thanks for replying !
This is what i got.
- plemansJul 15, 2020Guru - Experienced User
The t3 timeouts you're getting tend to be line issues.
If you have any splitters, attenuators, amplifiers connected to the coax line, I'd try removing them. I'd also recommend moving the modem to directly where the coax enters the home. This prevents wiring within the home from being the issue. Also check the coax for damage, corrosion, kinks, bad/cheap connectors.
If none of this helps, the isp should check the line.
- FURRYe38Jul 15, 2020Guru - Experienced User
Be sure your using good quality RG6 coax cable up to the modem.
