Sotelokid
Jul 13, 2020Aspirant
Modem Router Dropping Speed. Netgear AC1750 Wifi Cable Modem Router C6300v2
Recenlty bought this modem and ive noticed my speeds will drop. When i do a reboot my speeds will come back up 200mbps+. Not sure what is going on but ive checked to make sure things are connected a...
Jul 14, 2020Guru - Experienced User
speeds drop over wireless, wired, both? Or 2.4ghz/5ghz? Details are important since we aren't there.
when it drops, do you still pull full speeds over wired?
Do you have a screen snip of the cable connections page and logs?
I'd also recommend if you have any splitters, amplifiers, or attenuators in line to remove them from the coax line.
Sotelokid
Jul 14, 2020Aspirant
They drop on both ....wired and on wifi. its odd and yes let me get a snip and i will post again. Thanks for replying !
