Sotelokid
Jul 13, 2020Aspirant
Modem Router Dropping Speed. Netgear AC1750 Wifi Cable Modem Router C6300v2
Recenlty bought this modem and ive noticed my speeds will drop. When i do a reboot my speeds will come back up 200mbps+. Not sure what is going on but ive checked to make sure things are connected a...
Jul 14, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
- SotelokidJul 14, 2020Aspirant
I forgot how to check that again..how do i go about ? My isp told me everything was fine on their end, but of course they say it must be soemthing up with my modem.
- FURRYe38Jul 14, 2020Guru - Experienced User
If you have a android pad or apple pad you can install a free wifi analyzer there product app store and see what wifi neighbor signals are near by. Sometimes having lots of other neighboring signals can cause problems.
