Recario
Jun 04, 2020Follower
MODEM ROUTER EASILY GETS HOT
The Modem gets HOT easily after it was turned on. like 10 minutes the top surface is already hot. is this normal or the unit is deffective?
antinode
Jun 08, 2020Guru
> [...] HOT [...]
Define "HOT".
Hard to say, without knowing what "this" is.
If the thing works (for many years), then it might be normal.
If you're worried about it, then I'd complain to Netgear support
while the warranty is still in effect.
> To verify how hot its' getting, you'd need to get you a laser temp
> guage [...]
Or any suitable thermometer.
> [...] Then look at the spec sheet to see the temp range that is set
> for this modem.
I've never seen a "spec sheet" which mentions the case temperature of
a device like this. Has anyone?
Jun 08, 2020Guru - Experienced User
Technical specifications:
Feature Description
Network protocol and standards compatibility
Data and routing protocols: TCP/IP, DHCP server and client, DNS relay, NAT
(many-to-one), and TFTP client
Power adapter • North America: 120V, 60 Hz, input
• All regions (output): 12 VDC @ 2.5A output 30W maximum
Physical specifications • Dimensions: 9.25 x 6.1 x 2.25 in. (235 x 155 x 57 mm)
• Weight: 0.95 lb (0.44 kg)
Environmental • Operating temperature: 32° to 113°F (0° to 45°C)
• Operating humidity: 90% maximum relative humidity, noncondensing
• Electromagnetic emissions: Meets requirements of: FCC Part 15 Class B.
Interface Local: 10BASE-T, 100/1000BASE-Tx, RJ-45
802.11ac/a/n/g/b
Internet: DOCSIS 3.0. Downward compatible with DOCSIS 2.0, 1.1 and 1.0
- antinodeJun 08, 2020Guru
> Technical specifications: [...]
So? Please, help me out. I see no "case temperature" there. "Case"
and "Environmental" are spelled differently for a reason. For any
simple device which consumes power, I'd expect its case temperature to
exceed the ambient temperature.
Great animated icon, though. Love the useless "My Setup" info, too.
