petersito
Mar 30, 2022Aspirant
Modem Router is in Constant Reboot
I have Xfinity with an SB7 Advance Modem/Router and I decided to enable bridge Mode on the Comcast Modem. This way I could use my C7800 as a Wi-Fi router. However, after a while my C7800 Nighthawk ...
Mar 30, 2022Guru - Experienced User
The C7800 doesn't have a router only mode.
Why not get rid of the xfinity box entirely and just go with the c7800?
- petersitoMar 31, 2022Aspirant
Thank you for your advise! I will get rid off the Comcast modem but I first need to get the rebooting problem resolve in my Netgear.
- plemansMar 31, 2022Guru - Experienced User
connect the coax to c7800 so it can start initializing. Some combo devices won't go through the full boot sequence if its not connected to an cable connection (with link)
