Carbo2
Sep 06, 2020Tutor
Modem Status: Can Someone Decipher These Numbers?
I've been having ongoing issues for about a month. Half a dozen or so dropped connections every day. 3 or 4 minutes would pass and then I was back online. Took weeks of pleading with Comcast to se...
Sep 06, 2020Guru - Experienced User
your signals look good other than a bit high. but there's no errors so not as big an issue.
are you still getting t3/4 errors?
Are you using wan link aggregation?
What speeds do you get directly off the modem? (disconnect the router)
- Carbo2Sep 06, 2020Tutor
It's been 24 hours and no T3/T4 errors. In fact, not one entry in the log file.
I am not using link aggregation.
I haven't run the laptop directly off the modem yet, but I will in a bit.
