tbomb80
Jan 04, 2018Guide
Modem to router speed slower than Modem to PC speed - RP614v2
Hello all! So Xfinity recently upgraded my bwidth fro 75 - 100Mbps :) I tried testing this 2 ways. I found the speed to exceed 100 Mbps via speedtest, when my pc was connected directly to my cable m...
xtroublex
Jan 04, 2018Tutor
I am having similar issues with an older WNDR4300 Router Router Firmware Version
V1.0.2.96. I wire straight to the PC I get 300Mbs + when I go through the router, I get 200 or < 200Mbs.
tbomb80
Jan 04, 2018Guide
I'm leaning towards the port speeds on this thing. This router is ancient in terms of technology. Has served me well. So, I think I'm just going to try/buy a new one(probably the Asus RTAC68U )
- xtroublexJan 05, 2018Tutor
So, since no one has responded yet, I will share what I've done so far. I had a small 4 port unmanaged switch in the network so when I eliminated that, the speed jumped up! The problem with home networking tech is that you never know for sure when the problem is a worn out or defective piece of equipment. Unless it's just dead, it's difficult to think of it being "broken".
I'm still not at the 300Mbs that I should be, so I think I will need to simply replace my router, unless anyone has anything I can try.
- tbomb80Jan 05, 2018Guide
In my case, I think its just the router is too old. It doesnt even have gigabit ports. I just purchased the afore mentioned Asus router for a very good price. Waiting for it to arrive and will post results.
Nice!
I may be subject to the same. I think I will try as a last resort, loading the open source DD-WRT and if that doesn't work, I will buy a new one. Maybe the Nighthawk...
OH, I almost forgot, I also adjusted the MTU speed. I read the article below. Hope this helps you a bit.
- In Windows, go to Start and select Run.
- Type in cmd (Windows 2000/XP) or command (Windows 98/ME) into the Open: field. Hit the enter key or click OK. The DOS prompt should open.
- At the DOS prompt, type in ping www.yahoo.com -f -l 1492 and hit the Enter key:
- The results above indicate that the packet needs to be fragmented. Repeat this test, lowering the size the packet in increments of +/-10 (e.g. 1472, 1462, 1440, 1400) until you have a packet size that does not fragment:
- Begin increasing the packet size from this number in small increments until you find the largest size that does not fragment. Add 28 to that number (IP/ICMP headers) to get the optimal MTU setting. For example, if the largest packet size from ping tests is 1462, add 28 to 1462 to get a total of 1490 which is the optimal MTU setting.
- Change the MTU on the routers WAN Setup.
The result was a small increase (30Mbs)
