tbomb80
Jan 04, 2018Guide
Modem to router speed slower than Modem to PC speed - RP614v2
Hello all! So Xfinity recently upgraded my bwidth fro 75 - 100Mbps :) I tried testing this 2 ways. I found the speed to exceed 100 Mbps via speedtest, when my pc was connected directly to my cable m...
xtroublex
Jan 05, 2018Tutor
Nice!
I may be subject to the same. I think I will try as a last resort, loading the open source DD-WRT and if that doesn't work, I will buy a new one. Maybe the Nighthawk...
tbomb80
Jan 05, 2018Guide
Thanks for the advice on the MTU. I did the same process you did and then checked my MTU in WAN and it was already set correctly(to 1500). I think the router should make a big difference. Will let you know. I have an Asus RT-AC3200 for my wifi currently. Was going to get the Nighthawk but man that is very expensive. This 3200 makes a huge difference though and I can walk around outside almost 100yds from my house and still be connected. Very happy with this. Now I just need a wired router and thats were the AC68U comes in to replace this ancient RP614.
- tbomb80Jan 10, 2018Guide
Problem solved w/ the new router :) 120mb/s
