teter
Oct 24, 2020Tutor
modem to switch to modem long distance how should I configure the end router
I just layed a cat 6 cable from the modem in the house 200 ft to a outbuilding added a switch went another 200 ft to a building do I need to configure the end modem there other than the default setti...
Oct 24, 2020Guru - Experienced User
test it each step of the route.
Test it at the run to the switch (prior to plugging the switch in), then directly connect to the switch with a 6ft cable, then check at the Abnb.
find out whats restricting the speed. Maybe the switch isn't gigabit or one cable is bad (usually the end is bad and can be cut off and replaced).
teter
Oct 24, 2020Tutor
you were right on bad ends I redid the ends of the cable and went from 90 to 780 mbps to the switch thanks so much.Have renters now so will wait to finish. jeff
- plemansOct 24, 2020Guru - Experienced User
glad to hear you got that fixed!
Let me know how it goes with adding an access point in the AbNb.
- teterOct 26, 2020Tutor
I am using a new netgear switch but might be stepping beyond the netgear line asking this question here The router Im tring to make a access point is a linksys WRT 54G I cannot seem to find the whole picture on how to configure it for access point. It is in bridge mode as default but has the option to change to router. Also when you turn off DHCP and save settings I lose contact with the web based router panel. Is there a clear path to configure this router to a access point to be able to use the wireless as well as one of the 4 ports for a smart tv ? sorry Im a old person tring to figure this out . Thanks
- plemansOct 26, 2020Guru - Experienced User
That was a solid router when it was released.......17 years ago. It literally came out in 2003. It might be worth upgrading for your abnb.
But if you choose to go that route, there's guides on the linksys forum.
