chaparroblue
May 07, 2016Follower
MODEM/ROUTER C300 WIFI SIGNAL TOO WEAK
I JUSTINSTALLED MY NEW MODEM/ROUTER C3000 AND THE WIFI SIGNAL APPEARS TOO WEAK I'M UNABLE TOO OPEN WEB PAGES FAST ENOUGH OR SOME OF THEM NOT EVEN OPEN, I'M I DOING SOMETHING WRONG OR WHAT DO I NEED ...
VE6CGX
May 07, 2016Master
Run inSSIDer and Acrylic WiFi analyzer and see what the singal level is. How did you set up the wierless setting? WMM enabled? picked and seleceted a good channel? Using WPA2 security protocol? What is signal level in db shown on the inSSIDer or Acrylic. Just don' t say "Too weak"
Retired_Member
May 08, 2016That box is still a cheap POS I made the mistake of recommending it to my son in law. Return it!
