Kapalualogo's avatar
Jan 18, 2016
Modem/Router n450 3000v2 ip needs changing
I have just one (1) website that I cannot access recently and don't know why.   I have other computers and IOS devices that also cannot access only this website.  I can go to a neighbors home and use their wifi and there is no problem accesing the website.  I think for some reason the website is blocking my ip address from the modem/routher but I don't know how to change the address for this model.  Can anyone help?
  • Your public IP address is assigned by your ISP.  You may have to call them up and ask them to change it.  But it's often difficult to get them to cooperate.  You can try unplugging your modem for a day and hope that the ISP times out the IP address.  But this is not guaranteed to work.  IP address assignments are often sticky.  Good luck.
    • Kapalualogo's avatar
      Kapalualogo
      Guide
      Thank you TheEther...I have contacted my ISP (Time Warner) and they did a TraceRt and found that the problem was after their equipment handled the request so now awaiting the support group from said website.
        Kapalualogo
        Guide
        TheEther, why can't Netgear give me a solution to change the ip address?  With their wifi router on the market there are instruction as to changing the ip, but with modem/router combination, there is different settings. Apparently connection with the source website is being blocked..  This I know because I went across the street to neighbors and utilized his wifi, and was able to connect without any problem..  So my best guess is that the source website either blocks or doesn't recognize my computer (ip address).
