GMA23
Aug 22, 2023Aspirant
Modem/Router speed
Activated Nighthawk AC1900 WiFi cable router with voice (C7100V) in March 2023 with no trouble until recently. Connection issues occurred last two Sunday overnites. Issue disappeared on Tuesday but re...
GMA23
Thank you. Would it be worth reducing internet speed slightly to accommodate this model? Just two people in the house and I’ve only had it 6 months.
Aug 22, 2023Guru - Experienced User
if that's something the ISP supports, sure. 3.0 was mostly good up to around 800Mpbs max. Never really supported 1Gb and ISPs not mostly required a 3.1 modem to support 1Gb fully now days. If you can get by with less, then go for it.
At some point the ISP may stop supporting 3.0 modems and will required you to upgrade to 3.1 something.
