Spaulino
Mar 21, 2023Aspirant
moden CM1200 communication port closed
I am having problems with the communication port (44158) I connect directly to a netgear nighthawk CM1200 modem and it appears that the port is closed, I go to settings and no option appears to open ...
Mar 21, 2023Guru - Experienced User
The modem only passes data traffic to and from the ISP services. There is no router built in or traffic managing ports here. All would be handled by your direct connected PC or a external wifi router.
The ports in back are all WAN ports and thus can be assigned WAN IP addresses from ISPs that support this. Not all ISPs support this.
Spaulino
Well, i already knows that, so means that my moden has problems because im conecting a helium miner and goes green per 9 seconds and them port is close. Also tested witn my computer.
I think I'll have to return this and buy another brand
- FURRYe38Mar 21, 2023Guru - Experienced User
The mode is not responsible for keeping the port open. Again, only passes traffic to and from. It's up to the device or router to keep the port open and alive. Not the modem. The modem is just the messenger.
We can take a look at the cable connections page and event logs page here if you can post screen captured to see if there are any problems seen here for the CM modem.
- plemansMar 22, 2023Guru - Experienced User
One thing to keep in mind with the CM series (and any modem only series), is that they might have more than 1 ethernet port but the vast majority of ISP's only support 1 public ip address.
so if you have something else connected to the modem other than your helium miner, you're going to have issues.
Unless your isp is one of the RARE ones that support more than 1 public ip address, it needs to go modem----router----devices.
With nothing but the router connected directly to the modem.
