Spaulino
Mar 21, 2023Aspirant
moden CM1200 communication port closed
I am having problems with the communication port (44158) I connect directly to a netgear nighthawk CM1200 modem and it appears that the port is closed, I go to settings and no option appears to open ...
Spaulino
Well, i already knows that, so means that my moden has problems because im conecting a helium miner and goes green per 9 seconds and them port is close. Also tested witn my computer.
I think I'll have to return this and buy another brand
Mar 21, 2023Guru - Experienced User
The mode is not responsible for keeping the port open. Again, only passes traffic to and from. It's up to the device or router to keep the port open and alive. Not the modem. The modem is just the messenger.
We can take a look at the cable connections page and event logs page here if you can post screen captured to see if there are any problems seen here for the CM modem.
