Bob5545's avatar
Bob5545
Moden LED LAN Lights
Why on my Cable Modem is my LAN 2 light blinking green, and the LAN 1 light is off.
I only have two of these on these Modem, why not four, one for each port?
Comments,
Thanks
  • Two key pieces of information would be very helpful.  What is the model number of your modem?  Who is your internet service provider?
  • plemans's avatar
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
