soumeng
Dec 11, 2021Initiate
Monitor modem
Hi, I have Comcast as ISP, CM1200 as modem. And I used to have Eero 6 (1 router and 1 extender) which I have replaced with Netgear AX1800 (2 satellite and 1 modem). For last 2 weeks, I was facing ...
Dec 11, 2021Guru - Experienced User
You can view the event logs and the cable connections page the cm1200 to see how its been performing.
- soumengDec 12, 2021Initiate
Can you elaborate more on how/where can I check these?- plemansDec 13, 2021Guru - Experienced User
when you log into the modem, if you click on the internet icon, it takes you to the cable connections page.
there's also a section for the modem's logs.
https://kb.netgear.com/000059644/How-do-I-log-in-to-my-NETGEAR-cable-modem
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
