zooxmusic
Mar 28, 2023Tutor
Mostly my stupidity, looking if there is a way to enable home phone services on this CA x30 model
I just bought the AX 2700 my phone cable modem and realize there's no phone support. Is there a way to add it after the fact or is that just pointless and I need to return this one and maybe somebody ...
- Mar 28, 2023
If you want it included with xfinity, then you'd need to return it.
But you could always switch to a voip solution. Probably cheaper than xfinity's service anyway.
Examples: vonage, magicjack, Nextiva, Ooma
Mar 28, 2023Guru - Experienced User
zooxmusic
Mar 29, 2023Tutor
I realized that right as I googled VOIP's. I remember I had vonage which worked great, but now it seems the Ooma may have the best path forward for my the correct phone for my elderly mother AND to keep the phone number she has had for easily 70 years. THANKS
