zooxmusic's avatar
Mar 28, 2023
Mostly my stupidity, looking if there is a way to enable home phone services on this CA x30 model
I just bought the AX 2700 my phone cable modem and realize there's no phone support. Is there a way to add it after the fact or is that just pointless and I need to return this one and maybe somebody ...
  • plemans's avatar
    Mar 28, 2023
    If you want it included with xfinity, then you'd need to return it.
    But you could always switch to a voip solution. Probably cheaper than xfinity's service anyway.
    Examples: vonage, magicjack, Nextiva, Ooma
