bobd23
Apr 12, 2022Aspirant
moving a netgear router modem c7000v2
I set up my Nighthawk router modem model C7000v2 at a prior address. We recently moved (same ISP), but I cannot get the router modem to connect. ISP has confirmed there is signal to the new address...
Apr 13, 2022Guru - Experienced User
Yes, try a factory reset and setup from scratch.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
