bobd23
Apr 12, 2022Aspirant
moving a netgear router modem c7000v2
I set up my Nighthawk router modem model C7000v2 at a prior address. We recently moved (same ISP), but I cannot get the router modem to connect. ISP has confirmed there is signal to the new address...
Apr 13, 2022Guru - Experienced User
You can factory reset to get back to defaults but it should still connect.
The ISP says there's service to the address but was it checked? Are they able to see/ping the modem when connected?
did you connect right where the coax comes into the home so you ensure its not wiring in the walls or a disconnected splitter somewhere causing it?
- bobd23Apr 13, 2022Aspirant
Yes, ISP checked and were able to see/ ping the router. Yes, connected right to the main coax from the wall, no splitter. In fact, the ISP screwed up and assigned my netgear router/modem to the location where we currently have service instead of the new location (haven't moved yet) and we got internet in the new location (even though the netgear app didn't show it as connected). I called the ISP once we saw that the internet went down at our current location and they reassigned the netgear modem router to the new address and no internet. Called ISP again, they made sure the netgear router modem was assigned to new address, they pinged it and said all is good.
- plemansApr 13, 2022Guru - Experienced User
Sounds like they've been flip flopping it around in there system. If it was working before and then initially when it moved (but not back at primary residence) makes me wonder if you didn't get a poorly trained tech that messed up something in their system with the moving.
