burningbird's avatar
burningbird
Follower
Jun 18, 2020
Moving CM600 from Spectrum to XFinity
I have a CM600, currently set up for Spectrum. I'm moving to another state, where I'll be using XFinity.   Should I do a factory reset before attempting to activate with the XFinity? Or just follow...
  • FURRYe38's avatar
    Jun 18, 2020
    Yes. You might have the current ISP disassociate it from there system. Factory reset and then contact the new ISP to have them associate it with there system.
