rmish
Aug 10, 2020Aspirant
MTA Status
I installed my cable modem, CM500V, after we lost power due to a tropical storm here in NJ. Everything works except my voice line/phones. I contacted my ISP, Optimum, with no luck. On their end, t...
Aug 10, 2020Guru - Experienced User
I would relay this information to the ISP. They need to correct this problem.
rmish
Aug 18, 2020Aspirant
Thank you for your suggestion. I found out from Optimum that Netgear is not compatible with their voice services. I am returning the modem and I purchased one that is compatible (Arris).
