JadeB
Jun 30, 2021Aspirant
Multiple devices connecting to my router but say no internet. Only laptop is getting internet.
I'm not sure what model my it is but it's a router modem combo. It just says netgear24 on it and my provider is xfinity. Randomly stopped working when it got hot almost a week ago. It just started co...
Jul 01, 2021Guru - Experienced User
There is a recessed reset button on the back of the modem. Press this button in for 10 seconds then release. Need to walk thru the setup wizard with a wired PC connected to the modem. Refer to the installation guide for help on this.
JadeB
Jul 01, 2021Aspirant
I looked at the back and even the bottom of the router but I couldn't find a recessed button, just an on off button. There are a couple buttons on the front that I tried holding down before, but they didn't seem to fix the problem either.
Also I just had someone come over with their laptop that had been on my wifi before and they connected no problem. But my xbox and cellphone still can't connect.
FURRYe38 wrote:There is a recessed reset button on the back of the modem. Press this button in for 10 seconds then release. Need to walk thru the setup wizard with a wired PC connected to the modem. Refer to the installation guide for help on this.
- FURRYe38Jul 02, 2021Guru - Experienced User
You may have incorrect settings on the xbox and cell phone. Contact the mfr for these devices for additional help and information regarding there products. If other devices connect and these two don't, problem maybe with these devices.
- FURRYe38Jul 06, 2021Guru - Experienced User
Is the Xbox wired or wirelessly connected to the modem?
Try this, disabling WPA security on the modem temporarily. Use the web browser to log into the modems web page.
Does the xbox and or cell phone connect to the modems wifi at all. Re-enable WPA2 and AES after checking this.
JadeB wrote:I looked at the back and even the bottom of the router but I couldn't find a recessed button, just an on off button. There are a couple buttons on the front that I tried holding down before, but they didn't seem to fix the problem either.
- FURRYe38Jul 07, 2021Guru - Experienced User
Any progress on this?
