regalvoid
Dec 29, 2023Aspirant
Multiple DoS Attacks in Logs!
I know there are often false flags in regards to DoS Attacks but networking is outside my area of expertise and I have lost service a few times so I'd rather be safe than sorry. I have a CAX30S m...
- Dec 29, 2023
First read what microchip8 says.
Then look into why you have "lost service".
That almost certainly has nothing to do with DoS Attacks.
My wifi vanishes (as in it is not listed as an option from any of my devices) but none of the lights on the modem change.To deal with this symptom, start with the usual troubleshooting. First move, apply the latest firmware to the router bit of your modem router.
I have a CAX30S modem/router running firmware V2.1.6.2That's not a firmware version in Netgear's library for the CAX30S. Maybe they withdrew it.
CAX30S | Cable Modems and Routers | NETGEAR Support
That directs you here:
CAX30 Firmware Version 2.2.1.12 - NETGEAR Support
For more help check the section for your hardware. This place is for routers. You own a "gateway".
Cable Modems & Gateways - NETGEAR Communities
You might find something useful there.
michaelkenward
Dec 29, 2023Guru - Experienced User
