merncar
Sep 25, 2020Aspirant
My C3700v2 runs 5ghz but not 2.4 ghz.
How can I get 2.4ghz not working on my C3700v2? 5ghz works fine.
Sep 25, 2020Guru - Experienced User
Did it ever work?
What is the 2.4ghz led on the router showing?
did something change or were you changing anything?
merncar
Thank you for your help! I dont think it has ever worked. I dont think I have changed anything. My devices that require 2.4 ghz have not worked since i bought this. The LED flashes on both the 2.4 and 5.
