tntlord's avatar
tntlord
Follower
Mar 18, 2022
my c7000v2 Modem/Router combo keeps resetting
My Netgear c7000v2 will reset after about two minutes or so no matter what I do.
I tried resetting it, factory resetting it, unplugging the coax cable, plugging it in.
Nothing seemed to work and I cant access any logs or even the
nighthawk app because it resets before I can.
I haven't used it for maybe a few months, maybe somehow that is the issue?
Its not my ISP because, I called them (Xfinity) and they said it wasn't them.
1 Reply
  • plemans's avatar
    check your power supply. Maybe the wrong supply got connected. If its rebooting that fast and happening even when the coax isn't connected, its not making it through the boot process.
