AlexHm
Mar 05, 2023Aspirant
My cax30 has been working fine for 4-5 months but recently 5g wifi started dropping out
I have the same issue. My cax30 has been working fine for 4-5 months but recently 5g wifi started dropping out or significantly reducing its speed to ~ 5mbit(normal speed is about 400). Restarting he...
AlexHm
Sorry, looks like the problem has been solved by downgrading firmware.
Mar 06, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
