twmarshall
Aug 03, 2015Follower
My CG3000 is only working on one LAN port
ElaineM
Aug 05, 2015NETGEAR Employee Retired
Hi twmarshall,
Welcome to the community!
Does that mean you don't get lights on the other ports? If you don't get LED lights and you have a computer plugged into it, it's a faulty hardware. Just to be sure, you can loop the cable by connecting one end to another available port. If you still don't get lights, it's time to replace the unit.
