wdanwatts's avatar
wdanwatts
My iphone Netgear app won't connect to my C7800v2
My iphone Netgear app won't connect to my C7800v2 because its firmware is out of date. My ISP provider, Mediacom told me they WON'T push firmware patches to user-owned hardware. I called Comcast, and...
  • plemans's avatar
    Dec 15, 2023
    Which firmware version are you on? The minimum to support the app is 6.01.07.
    If you're on a older one, you SOL. Then you'd need to use the browser to manage it. That's my preferred method anyway as the app is super basic.
