wdanwatts
Dec 14, 2023Aspirant
My iphone Netgear app won't connect to my C7800v2
My iphone Netgear app won't connect to my C7800v2 because its firmware is out of date. My ISP provider, Mediacom told me they WON'T push firmware patches to user-owned hardware. I called Comcast, and...
- Dec 15, 2023
Which firmware version are you on? The minimum to support the app is 6.01.07.
If you're on a older one, you SOL. Then you'd need to use the browser to manage it. That's my preferred method anyway as the app is super basic.
wdanwatts
Dec 19, 2023Aspirant
Unfortunately it was sold with firmware 3.0.X, so yes, my ios app is useless.
Dec 19, 2023Guru - Experienced User
The C7800 should still work fine and is a docsis 3.1 modem. So it should be plenty fast.
Just that you can't manage it through the app for your ISP.
Shooties.
Again, I'm not a huge fan of the app anyway but it is convenient.
