UncleWashington
Jul 11, 2021Aspirant
My modem, Netgear CM500 isn't giving the correct speeds.
Hi everyone, so recently I purchased a CM500 for my internet plan for optimum. I was getting a little 300 download and 30 upload. Ever since I switched a couple days ago my speeds have been just awfu...
UncleWashington
There is a wifi router between the modem, and I am running wired as well.
Jul 11, 2021Guru - Experienced User
Speed test with a wired pc connected to the modem directly...
What is the brand and model# of the router?
- UncleWashingtonJul 12, 2021Aspirant
The router I have is TP-Link AC1750, Archer A7. I just tested directly to the modem and interestingly enough it gave me the same speeds im getting already.
- FURRYe38Jul 12, 2021Guru - Experienced User
Try testing a different wired PC...
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
