JCGlines
Nov 14, 2016Follower
My Netgear c3700 cable modem/router sounds an alarm every day at the same time
I don't know how to fix this. At 6:00AM each day the alarm in the router sounds and after a couple of minutes ceases. I want to stop this from happening. Can anyone tell me how to fix this? Thanks.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello JcGlines
There is no alarms that make a noise on the modem it must be something else that is around your modem going off. If its making loud noises I would suggest contacting our support if the modem is under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
