wellworthalsvin
Nov 23, 2021Follower
My Netgear CM1000 is not connecting with the router.
Hi, I have Netgear Nighthawk R7900P WiFi Router I was trying to upgrade to TP-Link Tri-Bank AX11000 WiFi-6 Router. I made the changes according to the guideline and switched cable modern and router...
Nov 24, 2021Guru - Experienced User
did you power off the cm1000 for 2 minutes with nothing connected? Even disconnect the coax cable.
then connect the coax back to it and power it on. give it a couple minutes to fully boot.
Then connect the router and power the router on.
