wellworthalsvin
Nov 23, 2021Follower
My Netgear CM1000 is not connecting with the router.
Hi, I have Netgear Nighthawk R7900P WiFi Router I was trying to upgrade to TP-Link Tri-Bank AX11000 WiFi-6 Router. I made the changes according to the guideline and switched cable modern and router...
Nov 28, 2021Guru - Experienced User
Any progress on this?
wellworthalsvin wrote:
Hi, I have Netgear Nighthawk R7900P WiFi Router I was trying to upgrade to TP-Link Tri-Bank AX11000 WiFi-6 Router. I made the changes according to the guideline and switched cable modern and router (R7900P) off and switching the router to new TP-Link AX11000 router.... Unluckily I am my Internet connection is not working from the new router AX11000 after swapped. Do I need to hard reset my CM1000 Cable Modem? Anyone experienced similar issue? Your suggestion will be appreciated.
