FiddleFart
Oct 21, 2021Aspirant
My router wont let my camera (wired)
Having trouble connecting my cameras to my pc and ipad. They show up on, items not currently connected to the internet, but but will not connect. I put them om on a permanent address, but on my dvr...
Oct 21, 2021Guru - Experienced User
we need more details.
1. what router do you have?
2. firmware on the router?
3. what modem/gateway is it connected to?
4. what camera system (brand and model) are you using?
- FiddleFartOct 21, 2021Aspirant
I have ....
1) RAX10 AX1000
2) V1.0.5.108
3) wired4) hiseeu ADVR8the biggest problem i can connect then i cant.I am using avg vpn- plemansOct 21, 2021Guru - Experienced User
does it work when you VPN isn't running?
What modem/gateway is the router connected to?
I got into my VPN to allow my cameras and yes it does work, butfor a short period like maybe 12 hours that im guessing.
My modem is netgear model CM1000v2
