Aktright
Aug 26, 2020Aspirant
My upload speed is very low
This started last week and was fixed by calling my ISP which they reset something on their end. Now a week later, I'm having the same problems this time them resetting on their end only temporarly fi...
Aug 27, 2020Guru - Experienced User
You're cable connections signal strength is very high. Optimal is -7.5dbmv to 7.5dbmv. You're hitting 13dbmv.
Its not causing any downstream errors and your upstream power looks fine but its still a bit concerning to be running that hot.
Do you have your modem logs?
Aktright
Aug 27, 2020Aspirant
I do. I'll add it as an attachment here. Do you think it's the modem or probably and issue that an Xfinity tech needs to fix when he gets here tomorrow?
- plemansAug 27, 2020Guru - Experienced User
The tech needs to check the line. Between your high power levels and your logs, you have power issues/signal issues.
