Wi-Fitty
Sep 06, 2019Follower
N-450, Need a firmware update
I've got a near 5 year old N-450 Cable Modem & Router. I just updated to Avast VPN, I've already had Avast Internet Security for years. It decided to do a network scan and found a problem. It said Vu...
Sep 06, 2019Guru - Experienced User
You'll need to contact your ISP and have them push FW as most Cable ISP handle all FW updates to connected modems. Some ISPs don't update user bought modems FYI.
You might consider getting into a newer generation modem.
Good Luck.
